H3 Aux button
H3 Aux button
Anyone know where to get a button that will fit into the aux places behind the gear shifter? I have looked at my local RadioShack and online but I can't find one. If someone could point me in the right direction I would appreciate it!
RE: H3 Aux button
ORIGINAL: tarheel_34
https://www.hummerforums.com/m_18502/tm.htm
RE: H3 Aux button
ORIGINAL: littlehummerboy
There are a few pics on this link of what other members here have done.
RE: H3 Aux button
Like Fireman said, you could go with the OEM aux. switch but it will set you back about 50 bucks. The GM part # is 88963884.There is also a pigtail connector that you will need also if installing aftermarket lights. Sorry don't know that part number at the moment.It's kind of a joke. The switch is like $24 and the little cheap-*** pigtail is $26, but you really need both so once again you're at GMs mercy if you want the factory look.
Also if going with the OEM aux light switch there are 3 pins marked A,B, and C where the switch and pigtail connect.
A = GND
B = ACC
C = +12V
Hope this helps.
A = GND
B = ACC
C = +12V
Hope this helps.
RE: H3 Aux button
ORIGINAL: Fireman
I would imagine you could get them from the dealership in the parts dept if you wanted them to look factory.
GM PART # 88963885
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $27.00
OUR PRICE: $24.37
This is the roof mounted light switch from same site:
GM PART # 88963884
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $27.00
OUR PRICE: $24.37
Both switches do NOT come with the wiring harness (P/N 19131428), although you could make your own.
simian
01-08-2007 04:25 PM
maximuss32
12-28-2006 10:59 PM
cheappc@hotmail.com
08-25-2006 04:47 PM
