Welcome to the Hummer Forums - Enthusiast Forum for Hummer Owners.
If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
My alpha won't start, i have read several posts on here about engine problems with this vehicle. When I try to start the car it will run very rough for a few seconds with very low rpm's and just quit. I tried both sets of keys so it can't be the anti theft because the indicator will turn off when i insert the key, i unpluged the battery, and that didn't fix it. I called onstar and they said everything was fine. Any suggestions? I can't get it to the dealer till monday. I hope there is just a quick fix for it.
This ad is not displayed to registered members. Register your free account today and become a member on Hummerforums!
You have ignition wires, I would check to make sure they are all secure, as noted a vacuum line could be loose or cracked. If it is not starting right away and you are pumping the gas pedal that is not a good thing to do with EFI. Just turn your key before you hit it to start and see if you hear the fuel pump run for a few seconds to build up your fuel pressure then turn the key to start without touching the gas pedal. You can aso disconnect the ground side of the battery and let it sit for 10 minutes than that will reset everything and then you have to reprogram stuff. Could have some bad gas?
__________________
H3 Black 2007.5
H3T BG Alpha 2009
