FYI, Engine Code P0171
#22
I just had Sears do an oil change and change my plugs at ~96k w/ Iridium and Platinum plugs. I am now getting the P0171 error when I didn't before.
P0171 DTC: System Too Lean
I guess I'll check my K&N and then call Sears.
#23
Next: If sears did not use AC Delco plugs, then you just wasted $$ on having them put in crap that will be fried in short order. This has been said here and at other Hummer, Colorado and Canyon forums before: If you have an I5 do not use anything but AC Delco plugs or you are asking for trouble.
#24
First: This thread is OLD.
I still am getting the error though.
I noticed people were saying to look at the intake, MAF, etc. The fat foam seal that goes out to the firewall seems fine and the intake box where my K&N is seems fine.
I did notice that there's a hose up near the hinge of my engine that was just sitting there. "1/2 GM6148-M 090505 AGB'. It seems like it could be the air intake vacuum line. Whether it's actually from my car or not we'll see but I think it's likely the culprit as people were saying it's possibly a vac leak.
Does this hose look familiar to anyone?
it's pretty strange as the car seems to run ok.
#25
All I did was use Search. It's not like I spent hours digging thru old posts. Anyways, I did have Search swap out the plugs for AC Delco Iridium.
K&Ns also have a rep for cracking, cracks leak.
The intake manifold bolts that fasten it the head have been known to vibrate loose and cause a leak.
#26
That hose was from the stock intake (underneath rear of the resonator box) to the breather port at the rear of the valve cover. Whoever put on your K&N must have left it there.
#28
Yup for me it was the hose. somehow one of them took it off when doing my plugs. they put it back on and everything was fine again. thanks
jerferg
10-28-2013 03:23 PM
Alex2012
10-01-2012 01:53 PM
