Fender flares
You have 4 options, well on 3 for aftermarket
E&G Classic
EGR
Bush Wacker
and of coarse OEM
The E&G's are available with or with out mud flaps. I personally like the looks of the OEM fender flares because the color and texture matches the H3 perfect. The Bush Wackers are the closest to the OEM with the rears being a 3 piece design were the E&G's are a 2 piece design.
E&G Classic
EGR
Bush Wacker
and of coarse OEM
I know all that because I have done my hoemwork. I just want to know if anyone is running the bush whackers to see how they like them. Anyways in a couple of months I am gonna have the flares and the fender bedlinered.
If you offroad at all, don't get the E&G flares unless you plan to trim the inside of them. They are very bad about retaining mud and packed sand because they have a large lip inside of them. Also, if you're running large tires (35's), they rub and scrape really bad in off camber.
Here the h3 comes with OEM flares i need to get larger one as my tyre still stick out about 2".
As for the rubbing It is not so much the flares but the mud flap and the sway bar
It is not that bad but if that concerns you lift it and the rubbing goes away
reidclymer
07-13-2007 10:00 AM
Ken06H3
10-10-2006 11:38 PM
