winshield wiper fluid pump quetsion
Old 01-22-2011, 04:09 PM
J.W.'s Avatar
Default winshield wiper fluid pump quetsion
Driving along today, the front windshield wiper fluid stopped working. No sound of a pump working when I turn the trigger on the wiper controls. The back fluid works fine and I can hear the pump.
My question: Is there one or two pumps for the front and back nozzles? If there is only one pump then I know it is a problem with the trigger. If there are two pumps, time to get out the multimeter.
Old 01-22-2011, 06:23 PM
RKSmith163's Avatar
There are 2 pumps and they are on the reservoir The one toward the rear is for the front washer and the one toward the front is for the rear washer. Not hard at all to replace and it is much easier if you remove your airbox. There was a TSB's on the 06's. I don't know about the other years. I hope this helps.
Old 01-22-2011, 10:44 PM
RKSmith163 is 100% correct there are 2 pumps. You may want to check your fuse block and see if the relay and/or fuse is blown first.
Old 01-23-2011, 01:44 PM
J.W.'s Avatar
Any idea which fuse it is? The manual shows fuse #16 is the rear wipe pump switch fuse but does not specify which one works the front pump. I went ahead and checked every one associated with the wipers but just curious.
Old 01-23-2011, 10:32 PM
J.W.'s Avatar
Well, it must have been something that I checked because the motor started working again. I guess it was a bad connection somewhere. Gremlins I tell you!
Old 01-23-2011, 10:55 PM
Glad to hear it is working again! Not sure which fuse/breaker it is myself.
Poss. it is a breaker that popped and reset. Like the one on the window motors.
Old 01-24-2011, 12:27 PM
J.W.'s Avatar
That's what I am thinking. Either that or just a loose connection. I shot some silicon spray to a few connections to counteract all the salt just in case. Glad I did not have to replace the pump because I was not looking forward that with it being so cold right now.
drmeek
05-09-2013 10:20 PM
John Taddeo
03-23-2009 08:51 AM
c5vette
01-29-2008 05:32 AM
HummerDriver
07-11-2007 04:53 AM
HummerGuy
05-31-2007 07:47 PM
Quick Reply: winshield wiper fluid pump quetsion
