Crooked H3
Thanks Doc. I'll let yall know the outcome
if gm says so....but how can a "stiff"frame flex in the rear while the front is level?is the front really even left to right?
if you lift/jack one side of rear up 1 inch will the other side go up?...i think so.
sumpthin fishey here!!
Why do you say that? Just curious. I have searched before I made this post and I'm not the only one with this problem. It's not the norm but there have been signs of it on other h3s. All of them sit lower on the driver side though. Mine sits lower on the passenger. By over 1" !!!. I haven't had time to unbolt the shackles and try docs suggestion but I will asap
Carfax is reporting based. Nobody reports the damage or repair, Carfax shows it clean. It is a BS Insurance Co. Tool so they can screw you on replacement values when a claim is made, but happily charge you top rates to cover it as if it were pristine.
If the repairs were paid for out of pocket, the next guy is none the wiser. Virtually all Insurance companies and many dealers will report work done, the rest is all a mystery.
Kinda like this: you take your H3 to the local GM Dealer, they can run its Vin# and give you a print out of all service, repairs and warranty work "performed at a GM dealer." If Spanky replaced the motor, diffs and transmission under his shade tree, GM and your Dealer don't know what Spanky did, when, or how.
After owning it now for about 9 months, I have noticed evidence of major body work (grille, bumper, RF fender & liner, RF door...replaced and re-painted). It was done very well; if not for the overspray I noticed in the engine compartment I likely would not have looked close enough to notice the rest. Also; 3 out of 4 brake calipers have been replaced, a complete custom exhaust... The body work alone was obviously major enough that it SHOULD show on a Carfax, but doesn't.
BTW, my H3 sits even, side to side (or at least close enough that it cannot be seen). If yours sits lower on one side in the rear, but is even at the front, then it seems like the only way for that to occur is for the body/chassis to be twisted.
TECHNICAL
Bulletin No.: 07-03-06-001A
Date: November 21, 2008
Subject:
Vehicle Leans Left and/or Right, Front Sits Low on One Side (Measure Ride Height and Relax Rear Leaf Spring Shackles/Bushings)
Models:
2007-2009 Chevrolet Colorado
2007-2009 GMC Canyon
2007-2009 HUMMER H3, H3T
Supercede:
This bulletin is being revised to add model years and remove VIN breakpoint information. Please discard Corporate Bulletin Number 07-03-06-001 (Section 03 - Suspension).
Condition
Some customers may comment that the vehicle appears to lean on one side. In most cases, the left front of the vehicle sits lower than the right front.
Cause
The rear leaf spring bushings or shackles may become loaded when the rear leaf spring shackle nuts are secured.
Correction
Measure the fender wheel-opening heights, front and rear, to quantify vehicle lean. Fender wheel-opening heights are related to, but distinct from, trim height (a.k.a. Z and D height). The front wheel-opening height is known as P height, and the rear wheel-opening height is known as R height. The P and R heights are not set at the factory, nor is a specification given for them. However, they are the most direct and repeatable measurement of what a customer would see as the vehicle leaning. Perform the following steps before measuring the fender wheel-opening heights:
^ Make sure the vehicle is on a level surface, such as an alignment rack.
^ Set the tire pressures to the pressure shown on the certification label.
^ Refer to Label - Vehicle Certification in General Information.
^ Check the fuel level. Add additional weight if necessary to simulate a full tank.
^ To ensure proper weight distribution, make sure the rear storage compartment and/or truck bed is empty.
^ Close the doors and hood.
P Height and R Height Measurements
P height and R height are measured the same way. They are the distance from the ground to the highest point on their respective wheel-opening, going through the center of their respective wheel. Record the measurements on the repair order.
If the difference from left to right for P and R height is 10 mm (0.39 in) or less, no repairs are suggested as the vehicle is within specification. If the difference exceeds 10 mm (0.39 in) for either measurement, relax the rear spring shackles/bushings following the procedure below.
1. Raise and support the vehicle on the alignment rack.
2. Measure the P height (front wheel-opening height). Compare the left front measurement to the right front measurement.
3. Measure the R height (rear wheel-opening height). Compare the left rear measurement to the right rear measurement.
4. Loosen the left front rear leaf spring nut.
5. Loosen the two left rear leaf spring shackle nuts (1).
6. Loosen the right front rear leaf spring nut.
7. Loosen the two right rear leaf spring shackle nuts (1).
Tip
You may need an assistant to help jounce the rear bumper.
8. Jounce the rear bumper three complete cycles to help exercise the chassis.
9. Tighten the left and right rear leaf spring shackle nuts.
Tighten
Tighten the rear shackle nuts to 85 Nm (63 lb ft).
10. Tighten the left and right front rear leaf spring nuts.
Tighten
Tighten the front spring nuts to 125 Nm (92 lb ft).
11. Verify that the lean condition is fixed.
12. If the condition still exists, perform the trim height inspection by measuring the Z and D heights. Refer to Trim Height Inspection in SI for further diagnos
Subject:
Models:
Supercede:
Condition
Cause
Correction
Tip
Tighten
Tighten
