coolant flushing kits-good or bad?
Old 07-16-2016, 06:53 PM
jayhawk714's Avatar
Question coolant flushing kits-good or bad?
I want, and need, to change out the coolant in my 2007 H3. What are the good or bad points on flushing kits? Are they better then just draining? Even if I do use a flushing kit I still would use a radiator flushing solvent and running the engine to running temp and such. Any and all ideas will be greatly appreciated!
Old 07-16-2016, 07:43 PM
WR3NCHE4D's Avatar
I prefer a coolant flush by a professional. Some things are just done better by a pro than a DIY because of available equipment. Make sure they use a coolant flush machine. Doing it this way removes almost all of the old coolant. Still use your cleaning solvent and coolant. Unless you can empty the block, radiator and heater core there will still be plenty of old coolant remaining. Using 60% Dexcool (not premixed) and 40% deionized water results in a factory coolant.
Old 07-17-2016, 09:36 AM
jayhawk714's Avatar
Thanks WR3NCHE4D. Good advise.
honda400ex2003
19
11-05-2015 09:40 AM
Johnny B. Epic
02-09-2012 09:35 AM
HumminNBoatin
04-24-2008 03:10 PM
importkiller
07-20-2006 04:11 PM
Rayvyn
11-24-2005 09:25 PM
Quick Reply: coolant flushing kits-good or bad?
