code U1041 abs light traction failed and parking brake light serv 4wd sys?
Old 11-15-2013, 08:01 PM
Alex2012's Avatar
Unhappy code U1041 abs light traction failed and parking brake light serv 4wd sys?
anyone got the code U1041 abs light traction failed and parking brake light serv 4wd sys?
when i press the brake all lights go away when i release abs light comes back the brake felt spongy and some times the dash says brake fluid level
fluid level is ok no leaks at any wheel and wheel sensor are connected after a trip for 5 m i erased the code U1041 using maxidas scanner it came back then turned the car off and on again it went away and never come drove it 10 miles back any help please?
2007 h3
any suggestion would be appreciated
Old 11-16-2013, 03:48 PM
PSE30's Avatar
Bearings gone grab your front tires and shake them youll hear and feel it clunking back and forth
Old 11-16-2013, 06:34 PM
Alex2012's Avatar
they are good no clunks or excessive movement or any sound any suggestion by the way the code mean
Loss of EBCM Communication what do you suggest ? to look for
mskarenbear
21
01-08-2015 02:30 PM
Jogi
12-24-2012 08:10 AM
LikinmyH3
09-04-2012 04:59 PM
oTurtlez
05-10-2012 11:14 AM
screaminhd
09-30-2010 09:29 PM
Quick Reply: code U1041 abs light traction failed and parking brake light serv 4wd sys?
