Blower Motor Malfunction - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
LinkBack Thread Tools Search this Thread
Old 03-06-2008, 08:14 AM
Default Blower Motor Malfunction
After starting my truck last night and turning the heat on, I discovered that my blower is not functioning! I started going through the basics - i.e there is power going to all 3 dials, heat is still coming slowly out of the vents, and when I turn the blower to max, I hear a metallic clicking sound coming from the lower passenger kick panel. I haven't had a chance to start tinkering with it yet, but I'm afraid this may be a dealer issue. Has anyone had this happen before? I did a search and noticed G Man did have a similar issue a while back....wondering if anyone has any more info on it since then...
Thanks in advance!
P.S - it was 13 degrees in Wisconsin this morning...I want to fix this ASAP!
Old 03-06-2008, 02:31 PM
Default RE: Blower Motor Malfunction
suggestions? ideas? anyone??
Old 03-06-2008, 02:32 PM
CWS CWS is offline
Perhaps the squirrel died ?
Seriously, someone will pipe up soon.
Cliff
Old 03-09-2008, 03:24 AM
2006 H-3 (Out of warranty) Went to turn on heat last night and no blower. Relays, fuses OK. I'll pull the motor and apply direct 12 volts and see if it works. If not, time for a new blower motor. If it does work, I'll assume the switch/resistor is malfunctioning. I'll keep you posted, let me know what you find out.
Old 03-10-2008, 09:58 AM
in a strange turn of events, I got in my truck over the weekend, turned the fan on, and it worked like a charm.
Should probably get to the dealer and have it checked out anyway. My guess is this isn't the last i'll see of this problem.
Old 03-10-2008, 10:40 AM
CWS CWS is offline
I HATE intermittent problems.
Cliff
Old 03-10-2008, 02:09 PM
Get it checked out, like you said, you don't want a problem like this in the dead of winter.
Old 03-10-2008, 02:19 PM
no doubt..i'll let you know what the dealer comes up with
Old 03-12-2008, 06:26 PM
Default Follow- up?
What was the outcome of this story? Did the squirrel cage come loose on the shaft?
Old 03-13-2008, 12:58 AM
Default RE: Follow- up?
i had this problem in my Colorado . the blower wouldn't work unless it was on 4. 1-3 didnt work. i replaced the heater resistor its under the love box on the blower at least in a rado and it fixed my problem. i hope this helps. it was only like 20-30 bucks for the new part.
heres a link to a write up on the issue on a Colorado forum
http://coloradofans.com/forum/viewto...=685146#685146
Reply
Thread Thread Starter Forum Replies Last Post
blower motor wkrpinnick Hummer H3 3 08-04-2011 06:22 PM
07 H3 blower motor switch fabguy1 General Hummer Talk 0 12-17-2010 07:36 AM
Blower Motor falure '03 H2 Thunder Cat Hummer H2 10 11-18-2010 04:24 PM
06 Hummer H2 SUT Blower Motor teamtitleist Hummer H2 SUT 3 09-16-2010 12:52 AM
Blower malfunction meesh General Hummer Talk 1 07-19-2010 01:36 PM
Tags
2007, 2008, blower, colorado, fan, forum, h3, hummer, location, motor, motors, problem, problems, recall, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
