Blower motor help
Old 10-26-2014, 07:56 PM
jerms212's Avatar
Default Blower motor help
I know I know - we all have the blower motor issues but heres where I'm at:
Bought this 2006 h3 used
A/c cut out 2 weeks later
Pulled the resistor - it was toasted
Pulled the harness - someone had tried to repair it previously and did a crap job
Replaced harness, resistor, and relay.
Blower blows now but air compressor does not kick in
Also, at the switch, 1 blows low, 2 cuts off, 3 & 4 blast warm air.
Checked the switch - no burn marks, I'd check the ohms but I don't know what values it should have.
Any pointers?
Old 10-27-2014, 07:58 PM
Brian McGuire's Avatar
Have your fan clutch checked by a pro.
Old 10-28-2014, 10:11 AM
jerms212's Avatar
I pulled the hvac controls apart and found a burnt circuit on the board. looks like I'm out $200 for a new switch.
Old 10-28-2014, 10:45 AM
happythree's Avatar
how bad is it? a good technician can fix burned traces.
post picture..
Old 10-28-2014, 11:28 AM
jerms212's Avatar
1st picture is what it's supposed to look like.
Second picture is after I put a blob of solder on it trying to see if it'd at least make a connection to blow air out of my dash vents instead of my defroster. You can't see the burned connection cause I covered it with solder and I'm away from my shop at the moment so I can't pull the solder off.
Attached Thumbnails Blower motor help-hummer-ac.jpg   Blower motor help-hummer-ac2.jpg
Old 10-28-2014, 02:28 PM
happythree's Avatar
nothing looks terrible.
you can use a small wire to jump where it goes' i cant tell by pix and never had that board out.
id try hard b4 the big $$!!
Old 10-29-2014, 10:30 AM
atvspeed4's Avatar
What color is your H3?
Old 10-29-2014, 08:48 PM
jerms212's Avatar
Black
08grayH3
06-11-2012 07:58 PM
fabguy1
12-17-2010 06:36 AM
Thunder Cat
11-18-2010 03:24 PM
teamtitleist
09-15-2010 11:52 PM
Ripskip
03-13-2008 11:17 PM
Quick Reply: Blower motor help
