Anybody have problems with their rear wiper not spraying any wash fluid
My rear windshield wiper will not spray any fluid out of it and it doesnt look clogged at all I see that little rubber fitting on thehatch it looks like something might be clogged in there because the hose inside the hatch looks like its bulging and on the outside its not pressurized. Is there any way I can unclog it? Has anyone else experienced anything similar to this?
RE: Anybody have problems with their rear wiper not spraying any wash fluid
i had this problem happen to me. you probably looked at your reservoir and saw that you had fluid. however, the fluid my be low enough that the pump for the rear is not catching any water for the rear.
I topped off my reservoir and that fixed the problem.
try that first. if not, a call to the dealer and they should fix it.
There is a TSB (Technical Service Bulliten) out on this issue. It's a defect in the rear wiper fluid motor/sprayer which is actually located in front near your fluid resivoir. The front and rear sprayer motors are in the same place. The rear one has a tendency to burn out after a while. It's covered under warranty and should be fixed for free.
I had it done on mine. The dealer should be able to pull up the information on it. It is covered under warranty.
ORIGINAL: HummerGuy
I never even got a notice for it. the only notice so far i got was for the jack.
Hey Mark. The jack situation was a factory recall. The TSBs are pretty much technical warnings sent out to the dealer service departments which tell the dealers there is a common situation that has been discovered and here is how you fix it. They don't issue recalls unless it is a safety issue. If there are common problems however, as our windshield fluid problem, the dealer will get the service bulliten with the exact part numbers and steps on how to fix it, IF available.
Be warned though; unfortunately as we have seen on this forum, there are a few Hummer dealers out there that don't even read the TSB's, which is very unfortunate because you pretty much have to go on the net and print it out and shove it in their face for them to pay attention to it. Hopefully your dealer has a good service department. All of the ones here in the Midwest are great though.
Mine was like that when I first bought it a month ago. Turns out the line was FROZEN. What kind of washer fluid does the factory use, anyway? The tech thawed mine out and I've been using Rain-X washer fluid ever since.
-- Frank
-- Frank
its the motor it burned out .it happened to me no fluid was comeing out,checked no clogs and plenty of fluid so i took it in since under warranty and they put a new motor in and we were cleaning again
Andreas_Sweden
18
02-16-2013 07:40 PM
minta7
01-14-2013 09:32 AM
HummerGuy
05-31-2007 07:47 PM
