any such thing as locking center caps?
Old 11-27-2006, 09:08 PM
whododat's Avatar
Default any such thing as locking center caps?
or is there a better solution then these things flying off
Old 11-27-2006, 09:48 PM
Fireman's Avatar
Default RE: any such thing as locking center caps?
I've seen locking hubcaps, not sure about center caps, but I thought I've seen them before. I don't know, however, if the H3's wheels can be made to except a locking center cap.
Old 11-27-2006, 09:59 PM
They should fit tight are any of the tabs inside broken.
Old 11-27-2006, 10:43 PM
whododat's Avatar
they certainly do not fit tight, none of the tabs are broken. i went to check into locking lug nuts and they(center caps) JUST popped right off with almost no effort. i am concerned that i will start losing them. [&:]
Old 11-27-2006, 10:50 PM
I know the chrome one fit nice and tight.
on the grey rims they have a metal ring inside them.
I had mine chrome plated and bought chrome ones they held on.
The chrome on the rims did not so i had to buy factory chrome rims.
Old 11-27-2006, 10:54 PM
whododat's Avatar
dilo
thanks, i will look into the metal caps. and by the way, I HAD to explain to my wife why i felt WE needed bigger tires.
just want to make sure of one thing, will the metal ones fit on the regular rims?
Old 11-27-2006, 11:05 PM
yes but they are chrome plastic with a metal ring inside
Old 11-27-2006, 11:10 PM
This is Dennis rim with the chrome center cap
[IMG]local://upfiles/111/88EBA00DE8C545FAA0898ED8FEEFE645.jpg[/IMG]
Old 11-28-2006, 12:28 AM
Ghostrider's Avatar
I have the gre/ay ones and they fly off all the time...in fact one is completely missing never to be found again. I tried running without for a while but it started to show rust on the wheel hub so I put them back on.
Old 11-28-2006, 12:34 AM
Ghost..Steel wool out your hubs (to remove the rust) then spray Rustolium's Clear Enamel on the hub area.
Quick Reply: any such thing as locking center caps?
