Alpha Vibration Rattle-at Idle-in Gear-Update
Old 08-10-2010, 06:55 PM
NIK1's Avatar
Default Alpha Vibration Rattle-at Idle-in Gear-Update
I finally found what was causing the rattle at idle.The the top gray engine cover was vibrating at the oil fill neck tube.I put a zip tie around the filler neck,screwed on the oil cap back on,and no more squeaky vibration.For some reason after the engine was hot,the cover was a little loose by the oil fill cap.All the fasteners were on tight,just a little loose by the oil cap.Good thing for zip ties...
Attached Thumbnails Alpha Vibration Rattle-at Idle-in Gear-Update-2010-hummer-h3-alpha-adventure-4.jpg
Old 08-10-2010, 09:06 PM
85_305's Avatar
Banned
My i5 does the same vibrating crap. I tightened the clamps on the intake and that helped some, but it still makes that annoying vibration.
rsm688
07-22-2014 11:07 AM
bearcsa
43
02-24-2013 01:44 PM
NIK1
07-02-2010 09:56 PM
calif phil
04-08-2010 05:19 PM
CCMDoc
08-07-2007 09:26 AM
Quick Reply: Alpha Vibration Rattle-at Idle-in Gear-Update
