AC Blower fix
#271
Lol. Hahahaha... I just called a dealership just to price their wire harness for this same problem. For an '09 H3T they wanted 98.00. But for a '06 H3 (the wifes) the same part is 140.00. Wow.
#272
Yep Voodoochild. The ac resistor (red connector) was melted into the male end. I couldn't see it until i had removed the pieces. #1 & #5 connections were melted together. Decided to replace the ac wiring harness and ac resistor. Pretty easy job once you remove the passenger side cover to the dash and the glove box. Ordered a new harness off ebay for about $48. My local Autozone carried the AC Delco AC resistor for $28. Got everything replaced. The blower worked but every time i would turn on the air conditioner, the air clutch fuse (48) would blow. After burning thru about 5 fuses i read somewhere to switch the ac clutch diode (90) and the windshield wiper diode (65). Both are the same and interchangeable. Air and blower now work wonderfully!
#273
Same thing!!
this thread has helped me!! Cleaned the resistor, now on to the next step!!! Thankful for this site!! Being a female, things may seem hard but this is so simple!!!😊
#274
Not the same thing!!
I seem to have a different blower problem than the wiring harness but I didn't think I should create a new Thread. H3 2009, last spring the blower stopped working, a cool summer I didn't worry about it, in the fall I started looking into it and these forum messages have helped me on what to look for.
So I checked out the resistor and wiring harness expecting to find it burnt but it looked clean. I checked the resistor and got some different resistances so I am guessing that it is good. Wiggling the wire harness around didn't do anything. Fuses were checked, switched around a few to be sure, but relays were not checked. The fan switch seems good (such the air conditioning light will come on when the switch is on but no blower). The blower did come on a couple times with no indication of a blower motor problem so I am ruling that out. Any help would be appreciated.
#275
Got it fixed
I finished it up last night. Cleaned the resistor out and the connector and got it back to working. However I'm only doing this temporarily until I can replace it. I pray it stays working until then. Thank u guys a lot!!!
#276
#277
Yes, I had take the harness out and separated it from the resistor before testing the resistor. The connections looked new, the resistor had some rust.
#278
Please help i am freezing
Hi guys, I am having the same issue. Replaced the resistor, the wiring harness and have checked all relays and fuses but still nothing. I am in more of a problem then you guys as I am in London, England and there are no GMC dealerships to take this to. I ordered the harness from the states and was hoping that would fix it but still no luck and its b00dy cold in London so I am having to make do with a 12v useless heater which doesn't even demist the windows let alone keep me warm.
Really desperate guys please help!!!! I love this bug truck but right now Its a hassle driving IT! It never was working when I bought it and I didn't think to check as it's such a unusual thing to happen to a car in London!!
To note the ***** are fine, when I turn them I can hear things happening, but no air comes out. I do get heat when the car has warmed up but I am guessing that's just from the engine bay comng through ??
#279
#280
Mine just stopped today. Spent 7 minutes reading this thread, 5 minutes pulling the resistor and plug part and cleaning them. Back up and running. I'll need to replace it. Just not yet. This forum is full of valuable information.
