2008 h3 bad vibration @ 70 mph....help
Old 06-21-2011, 09:38 PM
wkrpinnick's Avatar
Default 2008 h3 bad vibration @ 70 mph....help
I m looking at buying a 2008 h3 ..but at 70 mph. it gets a hell of a vibration in the rear... i think.. the dealer said wheel out of balance.. that did not work.. still the re maybe a little better....now the gonna put on new tires.. any have problems such as this /??
thanks wade
Old 06-22-2011, 03:26 AM
mthoodh3's Avatar
lets see, when i bought mine used with 38k they still had the factory tires on which were cupping, i had a bad rear shock, and it was out of alignment which i think may be your problem. check into an alignment first if you still have some life left in your tires. these trucks ride like a luxury car when everything is in order. good luck
Old 06-23-2011, 06:02 PM
wkrpinnick's Avatar
Default not sure what to think
the dealership said it is a drive shaft issue . do they bend? I have had u joints in the past go out that is a dead giveaway but a bad drive shaft..on a year old truck with 35k .. did i buy a pile or what
Old 06-24-2011, 07:10 AM
dan perez's Avatar
Modern aluminum driveshafts can bend and/or be dented very easily. Running over a blown tire on the highway can cause just enough damage to the driveshaft to cause a vibration at 70 mph. If I were in your shoes, I would let the dealer replace the driveshaft then take the H3 out for a test drive. Lovin' my '06 H3 !! good luck, dan
Old 06-24-2011, 07:40 AM
wkrpinnick's Avatar
Default thanks for the help
we test drove three or four h3s. one previous at the same dealer had the steering shaft or shock issue ..when hitting pot holes @ 30 or so clunked . so we picked out this one newer and less miles. we did buy it and bad on my part i just drove it around town. once we hit the highway and got to 70 mph the vibration showed up .. we took it back and here we are. I plan to let them do whatever it takes to make it right . I do have 30 days to decline the sale i think. besides i never made it home with the truck.. and they gave us our trade back so it s not like were stuck with some loner car.
thanks
CCAnger5404
04-24-2015 02:37 PM
xtremez28
12-15-2014 03:13 PM
bearcsa
43
02-24-2013 01:44 PM
HumminNBoatin
04-24-2008 03:10 PM
Billyboys
24
04-03-2007 03:18 AM
Quick Reply: 2008 h3 bad vibration @ 70 mph....help
