2008 H3 Air Conditioner Intermittent - NO burning smell
Hello World! Sharing my experience with what I feel is a neat vehicle. Does what it does for me. The A/C is a intermittent. Things I have done so far:
Asked the drivers (two) if they have ever smelled the good old electronics smoke, and that is all.
Options:
Check the wire harness under and behind the dash board.
Check the resistor, attached to the same.
Check the clutch on the air pump engagement.
I plan to do these things tomorrow or the next. Do you fine gentle-people recommend anything else? Thank you for the time. I hope that we can build a correct database for ppl trying to troubleshoot the same problem.
Options:
Welcome to HF.
Did you get your recall notice about the HVAC harness??? Might want to take a look https://www.hummerforums.com/forum/h...call-gm-35541/
Need more info. What do you mean by "A/C is intermittent"?
-The fan only blows intermittently (both heat and cool)?
-The fan blows OK, but the A/C (cold air) only intermittently works?
There are 2 common issues with the H3 climate control system. One is that the air temp is only cold when the (left) **** is all the way to cold; turning it even one click towards hot immediately goes full hot. That can be solved with a small resistor wired into the harness behind the switch (do a search). The other is the fan (blower motor) control resistor/harness, which has been addressed by a recall from GM.
As Doc said, have you had the recall done?
hockeygirl
02-03-2009 08:03 PM
RealJeep
04-30-2008 11:59 AM
