2006 H3 Red Oil Lamp coming on
All, I'm new to this board and was wondering if anyone has ever experienced their red oil lamp coming on intermittently? I changed the oil and filter (I used the Rotella oil that someone suggested) and that helped for about a week. Now it's coming on again. It's a 2006 with 109,000 miles. Had the transmission replaced at about 65,000 miles. Doesn't come on while driving. When I drive about 10 miles, then stop, the light comes on. Then goes off when I start driving again.
Thanks in advance!!
Thanks in advance!!
when you stop , rpm is lowest,600. pressure is lowest. hit gas while stopped to 1000-2000 rpm. if light is out you have pressure problem if oil level is ok.
with a real gage you could see it drop huh.
my jeep gage drops to 35-40 in gear at idle, goes to 40 -55 running on the road.
a real gage would be tubing fed from the sending unit but i cannot find a fitting that fits the opening.
Thanks in advance!!
Thanks in advance!!
Use Mobil 1 synthetic (dexos approved) ..GL
flacofuller
12-18-2009 12:27 PM
hummer07
11-18-2008 10:46 AM
JeepeaterH3
09-10-2007 07:14 PM
