06 H3 drivers door
06 H3 drivers door
Does anyone know what the Door Check does? The one in my drivers door seems to be making a grinding noise when opening and closing the door. If has to be replaced do you need to take off the door panel?
thanks in advance,
Paul
thanks in advance,
Paul
Before you pull anything off, check the detent hold open bar/pin and lubricate that appropriately.
It won't hurt to try and lubricate the top and lower hinges too.
Use the lubrication cans that have the plastic stem for the nozzle.
That can get into places where you want to spray.
On occasion, my doors seem to drag and need this procedure
This is just my opinion, before you try and do a major job.
Good luck
Good luck
morad
11-24-2010 04:44 PM
jasonus03
05-29-2010 09:13 AM
imikeh
12-14-2009 05:10 PM
