Removing fuel door
Old 03-16-2015, 04:37 PM
mrcool's Avatar
Default Removing fuel door
Old subject I'm sure but how do you remove oem fuel door assembly so it can be rechromed? I loosened the three small screws around the filler tube inside the plastic bucket it seemed to loosen the filler tube but not anything else any help would be greatly appreciated.
Old 03-17-2015, 02:57 AM
LoJac963's Avatar
There's tabs inside the cup, 3 I believe. I need to pull those in to let the whole assembly loose to remove it. I forgot to add that part to the other thread.
Old 03-17-2015, 07:09 AM
mrcool's Avatar
These tabs are behind the fender itself and do you remember how to release these tabs psh pull turn ...
Old 03-17-2015, 02:35 PM
LoJac963's Avatar
pull them inwards to release them. That's how I got the thing out.
Old 03-31-2015, 12:19 PM
gocatgo11's Avatar
Hi LoJac963, are there any pictures to show how to do this? I think it would be helpful for many who doesn't know what they are doing like myself.
Old 03-31-2015, 09:11 PM
LoJac963's Avatar
I went through all my pics and unfortunately I do not have any pictures of the back of the lid or the bucket. Sorry.
If you open the door and look at the bucket there are slits cut into the bucket towards the front, that is where the tabs are. Once the 3 filler neck screws are removed you need to pull those tabs inward to release the bucket. Everything comes out with the bucket. The door is attached to the bucket itself.
Old 03-31-2015, 09:25 PM
gocatgo11's Avatar
Thanks Lojac963, I'll go check it out and if I have some other questions I'll be sure to hit you up if that's ok.
Old 04-01-2015, 12:38 AM
LoJac963's Avatar
No worries, I'm on all the forums multiple times a day. Either post here or shoot me a PM and I'll see if I can help you out with any questions!
ingydrummer
07-08-2014 06:17 PM
mgurgone
12-11-2011 09:13 PM
Davidh3
11-10-2011 04:51 PM
BIGT2148
10-20-2009 12:57 PM
blackstangs281
05-09-2006 03:42 PM
Quick Reply: Removing fuel door
