XM/Onstar antenna
Old 09-20-2012, 10:24 AM
PaulB's Avatar
Default XM/Onstar antenna
OK, here's a tough one. The rubber/foam part of my XM/Onstar antenna (shark fin) has broken in half. Went to the dealer to buy a new one. He brings out a replacement that looks similar but it just twists in place. Mine is attached to the base with two small torx screws. He says they must have changed the design mid-year. His book doesn't even show mine. I would have to buy a new base that accepts the new twist-on antenna. And it looks like the base is removed from under the roof, above the head liner. I have an 05 H2. We even checked the 04 model to see if maybe my style was listed but that antenna is totally different. Any suggestions? Thanks.
Old 05-21-2016, 12:26 AM
Dry Heat's Avatar
Default Anttenaaa P/N 20842596
I know this is a old post, but maybe some will be looking jut as I was for this antenna. P/N 20842596. Check E-Bay priced as low as $18.00 to $40.00. Just unscrew broken antenna and screw in new one. No need to remove the base.
Old 05-21-2016, 09:10 AM
PaulB's Avatar
This is the version I mentioned in my original post. This does NOT fit my H2. It is the twist style. These are available everywhere. Amazon, the dealer, ebay, etc.
Old 07-17-2019, 03:55 PM
Thelegend's Avatar
Just bought a 2005 H2 have the same problem with the antenna did you got the right antenna
Old 07-17-2019, 07:36 PM
PaulB's Avatar
No never did. Had to rebuild mine using bonding putty.
Threedog
06-29-2014 05:41 PM
VMAC
12-31-2013 06:47 PM
staggs
07-14-2012 11:27 AM
drtom
04-20-2012 10:50 PM
crank
06-17-2007 08:51 AM
Quick Reply: XM/Onstar antenna
