Wont go into four wheel drive HELP!
I have a 2005 Hummer H2 and when I go to put it into 4 hi lock the light just keeps flashing and it never completes the switch. Any ideas to how to fix this. Thanks in advance.
I have a 2008 H2 and found that I couldn't switch out of the "everyday" setting for 4 wheel drive. An inspection revealed that the transfer case mode selector switch had shorted. The switch itself cost $342.96 and labor was one hour. The switch number was 25878427:switch (04563-CT). I hope this helps.
Pretty much only two things it can be. Asanti just listed one of them. the other is the actuator motor bolted into the side of the t-case. Mine when bad, it was about 160 dollars to replace. took two minutes to bolt in myself and voila. problem solved.
tbraly
04-19-2014 08:36 AM
NJTEX
11-10-2007 10:26 PM
alphafourwheeldrive
02-13-2007 07:33 PM
