water pump leak!
Old 01-30-2008, 02:22 PM
jstdoitt21's Avatar
Default water pump leak!
Hi, I took my h2 to the dealer to get a oil change and when they do there 28 point inspection they said there was antifreeze leaking, i don't believe everything the dealer says so i took it and got it pressured tested somewhere else and they said there was a leak at the bottom of the seal?? They are telling me that i need to replace the water pump is that true or is it fixable? Also if i need to replace it, what would be a good price for a water pump and installation? They told me they had to take the hood off etc is that true?
Thanks you guys are alwasy the best
Old 01-30-2008, 02:29 PM
shortbus's Avatar
Default RE: water pump leak!
there's no technical reason to have to take the hood off, it probably just makes it easier to work on the center of the truck. it can be done without taking it off, but you'll need to reach in from the side. it they want to charge labor to take the hood off, they're just looking to rip you off. don't know about the costs yet, i haven't had to replace mine.
Old 01-30-2008, 02:32 PM
blackstangs281's Avatar
Pump is around $145.00.
Old 01-30-2008, 02:34 PM
Muddydawg75's Avatar
MSRP on an 03-05 water pump is $251.44
06 is $260.00
07 is $255.62
I see no goodreason to take the hood off... skidplate, yes.
and... while you/they are in there change the two serpentines....
Old 01-30-2008, 02:40 PM
jstdoitt21's Avatar
THey want to charge me $400.00 for parts and labor, does anyone know a good place to takes hummers for mechanic work in the Los angeles or orange county area?
What are serpetines?
Old 01-30-2008, 02:46 PM
ORIGINAL: Muddydawg75
06 is $260.00
07 is $255.62
Where the he!l are you buying your pump?
Old 01-30-2008, 02:51 PM
He wanted to know costs... a dealership isn't gonna give him any breaks...
Mine would cost me $165....
and that isn't far fetched... I just installed one on a 8.1L for workand my companies cost was very close to what I posted for my cost..
Old 01-30-2008, 02:59 PM
jstdoitt21's Avatar
Its not from GM, it's an 03 h2 costing me 150
Old 01-30-2008, 03:02 PM
Ok then.... you're probably getting a rebuild then....
I generally use OEM parts.. so I pay a little more and do it half as much.... but that point can be argued...
Old 01-30-2008, 03:03 PM
jstdoitt21's Avatar
Muddy did u buy that part from gm or really doesn't matter, the water pump that is not gm is costing me $150
Quick Reply: water pump leak!
