Water Leaks from ceiling above Front Windshield
Old 11-07-2010, 03:50 PM
BoneChief13's Avatar
Default Water Leaks from ceiling above Front Windshield
I have a 2003 Hummer H2, and I have found a leak in the vehicle. It is running down the front windshield on the inside. I think it might be from the Marker lights, but how do you get those off to fix the seal. I heard they pop off, but it seems like it would break when I attempt to do so. Can anyone please advise. It rains a lot where I'm at and its actually sunny today. Thank you so much. oh, I have the adventure model, It doesn't have the moon roof.
Old 11-07-2010, 04:03 PM
twr1's Avatar
Hi to remove the front middle 3 clearance lights go under the light and the weatherstriping on the side where the little slot is at the bottom with a thin piece of plastic or a small screw driver rapped in tape. Their is a release clip you push in on and the light will pop up.
Old 11-07-2010, 04:50 PM
Thank you so much, has been that way for a while now, just afraid it was going to break haha, I'll give it a go and tell you how it goes. Thanks again.
Old 11-07-2010, 05:43 PM
twr1's Avatar
Hi also check the 2 corner clearance lights unscrew them and lift them up. You will see a rubber gommet under them that the wires go through some times water can get inside the truck around the outside of the gommet but usally the water is in the corners of the headliner or down the pillar. Just use some rtv on clearance lights gaskets and around the gommets that will fix the water problem.
Old 11-07-2010, 07:50 PM
Circuitguy's Avatar
It’s common for the H2 to leak at the upper center three marker lamps. If there bumped or the foam seal dries out they can easily leak. You will need to replace them with new ones as they are not serviceable. Easy to do, just a small standard screwdriver is needed to do this. I you need any help with the removal and installation give us a call, one of our techs will help you out no problem...
Old 08-07-2011, 07:09 PM
TWISTED SIGNS BY DESIGN's Avatar
also keep in mind that the star screws that are on the roofrack may cause a leak,just take them out and clean them but make sure to put the small o-ring gasket on the star screw,all h2 hummers have this..if the leak keeps going then take the roofrack off,under that you will see a seam,just put some silcone on the seam from front to rear.just a friendley reminder.
jbs45
11-01-2021 11:38 AM
Propst72
05-05-2016 05:08 PM
RAHF
02-06-2015 10:26 PM
nicos
02-24-2008 09:07 AM
HummerGuy
10-13-2006 03:55 PM
Quick Reply: Water Leaks from ceiling above Front Windshield
