Upgrade Grill Guard spot lights
Looking for info on what can be done to make the process easier. My 05 has factory spotlights with a switch on the headliner panel. Id like to remove the spotlights and install and LED bar but would prefer not to have to remove the entire interior to run the wires to an existing switch. Anyone done this mod and have any tips?
If I have to remove the headliner any tips on that?
Factory lights are working fine. I'd like to use the factory wiring to install by light bar, just curious if anyone else has done this and if so did they have any issues or is this not possible?
I am fabricating a connector to go from the stock wiring to the new light bar. Just waiting on parts.
Understand now. I would imagine with the new light if it's LED that it should pull less voltage and one relay may be enough. Let's have a wiring guru time in (I'm just going off limited knowledge of LED's and trying to help. I'm punting-who is gonna run with this? Sorry I didn't help more.
Are the two relays to make sure that they do not come one without the truck running? I assume that one relay is for the switch and the other would be to make sure the lights do not drain the battery while the car is off. I never had the grille lights but I mounted two on a light bar I bought. I ran a single relay off of my high beams, I feel if I had a second switch that I would never use them, plus when the car is off, while the high beam stalk is forward (away from the driver) they will not turn on, but I can pull the stalk and hold them on while the car is off.
[IMG][/IMG]
Future H2 Owner
09-18-2014 08:48 PM
2007h3x
02-19-2010 08:45 PM
melvynray
10-07-2006 09:07 PM
