Transmission read hot
Old 04-19-2013, 03:13 PM
Charlio's Avatar
Default Transmission read hot
Drive my 03 H2 around all morning today and on the way to work this afternoon the reading started saying transmission hot? Any suggestions, please!
Old 04-19-2013, 05:15 PM
Man1nboat's Avatar
Are you referring to the gage reading hot? Obviously I'm not there so forgive the thoughts here... Is it actually hot i.e. do you smell anything, does it operate ok, etc? Is the fluid burnt i.e. dark, smell funny, etc? If it is operating OK then it could be the gage. If it is a message from the message pane then it could be other items i.e. sensor, wiring, etc... I'd be careful here money and safety-wise... Good luck
Old 04-19-2013, 05:24 PM
Charlio's Avatar
Reads hot and doesn't want to shift gears. Digital read out says hot and gauge is reading hot. Doesn't to shift out of first it feels like. Revs up real high.
Old 04-19-2013, 05:52 PM
H2CANEPADESIGN's Avatar
Time for a visit to the trans. shop! Find a reputable guy in your area and go from there.
Old 04-19-2013, 07:26 PM
Man1nboat's Avatar
Man... I would have it towed.
Old 04-19-2013, 09:27 PM
calif phil's Avatar
Check the fluid level, my 2003 busted the trans cooler in the radiator and it put coolant in the trans, it wiped out the trans and the whole cooling system. $5000 repair.
Old 04-20-2013, 11:23 AM
Charlio's Avatar
Ok checked the fluid and that seemed fine but it definitely smelt burnt. It was a pinkish color though. Drive around the block this morning, shifts fine until you hit 30mph then revs up and doesn't want to shift? !!
Transmission shop not open till Monday. Any suggestions on what it could be?
Thanks for your replys.
Old 04-20-2013, 09:39 PM
calif phil's Avatar
It sounds to me like you need your transmission rebuilt. How many miles does it have on it?
Old 04-20-2013, 10:27 PM
Man1nboat's Avatar
Yeah... You know, I had a friend that used transmission flush (BG), ran it for a few miles, and had it flushed at Grease Monkey. Maybe worth a shot since you need a tranny fluid change anyway...?
Old 04-21-2013, 06:51 AM
Charlio's Avatar
I have 82000 miles on it. Taking it first thing Monday morning hopefully won't need a whole new transmission
Quick Reply: Transmission read hot
