Transfer case noise and movement
Old 07-29-2010, 05:08 PM
roycel's Avatar
Default Transfer case noise and movement
I have a 03 H2 with about 39k on it.. I got it in Dec with about 24k I drive alot of hwy but haven't takin it off road in past 8 mths at least a dozen times.. Not hard stuff little mud and some dunes it has a 4 inch rancho lift and 37 nittos.. Now for problem it is making a clunk when you go into drive or when you give it gas from a coast (like a u joint noise).. I jacked up wheels and checked all u-joints and ball joints etc.. all are good but with front wheels in the air, truck off, and in park the front driveshaft well free turn about a 1/4 turn before it catches and stops when it catches it makes about the same noise like a metal just hit metal and grabbed.. what could this be? I spent alot of time looking at old threads and didn't find one the same
THANKS!!!
Old 08-02-2010, 12:30 AM
parabat's Avatar
Check your gear box to see how the bearings are. Mine went and it destroyed every thing inside the gear box. Cost me $3500.00 to repair. The shop told me that this is a problem with H2's since they are a tad heavy.
Old 08-02-2010, 09:49 AM
roycel's Avatar
So did you have the same kind of sound and movement of the front driveshaft before your tranny went out?
Old 08-03-2010, 06:26 PM
parabat's Avatar
I had a slight vibration that you could hear and feel in the front end that I felt through the steering wheel and floof. I had it for about 35 kilometers then the drive shaft dropped. When I first felt it I stooped and took a look but could not see any thing wrong. There as a small spot of oil on the drive way as the only other indication.
Turned out to be a bearing that went in the front end.
Hope this helpped
Man1nboat
01-19-2015 02:56 PM
screaminhd
06-11-2013 03:33 AM
djadds
09-25-2012 07:45 AM
hummerhank
01-02-2011 07:56 PM
Dan1127
05-03-2010 02:52 PM
Quick Reply: Transfer case noise and movement
