Transfer Case Encoder Motor Replaced!!
Old 08-08-2016, 02:36 PM
igolf2's Avatar
Default Transfer Case Encoder Motor Replaced!!
Just a quick note : I was getting the "service 4 wheel drive" indication every time I started my 2004 H2 - I was worried that one day the transfer case motor would quit completely so I purchased a Dorman Transfer Case Motor #600-908 but it did not function correctly ( you have to change out and move the connector pins and I did not want to hassle with that )
I ended up purchasing this : ACDelco 89059688 GM Original Equipment Transfer Case Four Wheel Drive Actuator with Encoder Motor off Amazon for $218 and in less than 45 minutes my problem is solved!
Spend the extra $ for the original equipment actuator and if you have put the TC in neutral and the TC shaft does not match the new TC encoder motor just use a crescent wrench to move the TC shaft to match what the motor is set at.
No more codes, Hummer shifting perfectly !!!
Old 08-08-2016, 06:11 PM
flyday58's Avatar
Mine would crap out any time the temp went below about 35º but would come back after the drivetrain was thoroughly warmed up. Went the same route as you, no problems since.
Old 01-27-2019, 04:38 PM
Chris Haeg's Avatar
Default I also bought the Forman but have not installed it yet?? Pin replacement is needed?
help please
No more codes, Hummer shifting perfectly !!![/QUOTE]
Old 01-28-2019, 12:32 PM
calif phil's Avatar
Your lucky you went that route, most Dorman products are cheap crap.
Baja
04-13-2020 12:17 PM
Happy Hummer
03-10-2018 10:34 PM
Knightblade
11-16-2017 09:51 AM
sgtfriday
02-21-2017 10:34 AM
altopolski
08-10-2014 01:04 PM
Quick Reply: Transfer Case Encoder Motor Replaced!!
