Towing Question ? - Hummer Forums - Enthusiast Forum for Hummer Owners
Reply
Thread Tools Search this Thread
Old 02-13-2017, 04:26 PM
TeeStu's Avatar
Default Towing Question ?
I may have to trailer a vehicle 1200 miles (Arkansas to Arizona) and tow a Boat & Trailer back. The vehicle and trailer will weigh 6350. The Boat and Trailer will be slightly less. My H2 is stock with 74000 miles. This will be in the next couple weeks so cool weather. Any concerns that far with that weight ??
Old 02-13-2017, 06:09 PM
Based on what I've read my only worry would be the transmission. I'd be looking very close at swapping the transmission cooler to a larger aftermarket on real quick.
Other than that I'd think you be fine myself.
Old 02-13-2017, 10:10 PM
H2Miami's Avatar
Mixmansc ... getting an aftermarket cooler is a must but I don't think is needed right now as he is trailering in cool weather . With 74k miles tranny should be still as new Make sure to use the trailering option .any chance you find hills with ice or snow on the way? Stopping the beast with a heavy load isn't a joke .
Old 02-14-2017, 08:20 AM
Keep the tranny under 200 use tow mode. I had a hard time keeping it under 200 even in cool weather but once I put the tranny cooler on, it has never been a concern. You can do it but you'll need to take your time and watch closely.
Old 02-15-2017, 09:32 AM
TeeStu's Avatar
Quote:
What Cooler did you use ?? Did you do the install or have it done ? Difficult ?
Old 02-15-2017, 04:37 PM
I followed this thread:
H2 external tranny cooler
I did the install myself and not difficult. But I know my way around a car and have a decent set of tools. The thread should help you out.
Old 02-15-2017, 07:15 PM
H2Miami's Avatar
The mod isnt hard to do . Only hard part was to cut the tranny pipes . I used a very small plumber cutting tool
Also make sure to get a very good tight clamp for tge hose attaching to the tranny pipe . It got a lot of preassure
Old 02-16-2017, 09:00 AM
My tranny cooler let go on my 2003 years ago while towing. $5000 later it was repaired. I would definitely add a tranny cooler. If you don't want to mess with it find a local tranny shop to install one for you.
Old 02-16-2017, 01:36 PM
citiboy's Avatar
I didn't cut any trans lines when i installed mine.
Here's what i did.
1. Disconnect the upper line from the radiator.
2. Connect the hose (included in the kit) straight to the new external cooler. Cut to length.
3. Disconnect both the oem trans cooler lines from the radiator cooler and trans line coupler end.
4. Connect the other hose.
5. Plug both the radiator cooler.
Done.
The beauty about this set-up is if the external trans cooler fail for whatever reason, just disconnect both the trans lines from the external cooler hose and reconnect both directly to the radiator cooler.
Old 02-17-2017, 08:19 AM
Ditto, didn't have to cut any existing lines.
Reply
Thread Thread Starter Forum Replies Last Post
Towing question TexMike New Member Area 0 01-24-2012 03:56 PM
Towing Question Luis! Hummer H3 7 01-07-2012 03:19 PM
Towing Question HummerTrucksGuy Hummer H3 4 09-14-2011 08:10 PM
SUT Towing Question constantini7 Hummer H2 SUT 2 09-27-2010 12:23 PM
Towing Question H3 Xman Hummer H3 3 06-08-2009 06:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
