sunroof wind deflector rattling
Are you sure its the deflector? I thought that was my problem, but it turned out to be the actual glass for the sun roof. The motor wasn't aligned properly and it was causing the glass to vibrate. The only way I figured it out was that I happened to push up on the glass while driving and the rattling stopped...
Just a suggestion before you glue something and it ends up being something else.
Best of luck getting it fixed
The wind deflector should be held on with 2 screws AND the addhesive tape. You can ask the dealer for the brackets and screws without having to replace the entire deflector. If that doesn't stop the rattle then it's probably the trim around the windshield.
