sagging
sagging
im new on here I have a 2006 H2 sut i came out 1 morning and my rear was all the way down, there is no error messag on the display
i checked both sensors our hooked up, i jumped relay over and the compressors work they pressure is not getting to the bags, my light in the rear and on the dash that you push for 2 inches more is on, i think it is either a control moldule, bcm or the control valve. i was wondering if this is a common thing.
no when i jump relay it will pump until it blows out bleed off, i check the valve above and no presser, it has a solinoid that opens up so air can get to bags, buts its not opening, the pumps wont kick on unless i jump it and there is no error that shows up on the bcm ( warning ) and my rear end is completely down.
rockstarbass1
01-02-2015 09:52 PM
