Roof Marker lights
Old 08-30-2011, 09:27 AM
SD_Hummer's Avatar
Default Roof Marker lights
I have an 04 H2 and was wondering what was the best route to go for replacing the stock roof marker lights. Websites would be helpful. Are they easy to install?
Old 09-01-2011, 02:17 PM
2004H2's Avatar
Default Thats 2 of us...
My end lights went out 2 days ago, my centers are getting dim so i was going to replace all the lights.....................
I called the the dealer to find out how to replace the 3 front and rear clearance lights,
they are wired with connecters Push-lock and are easy to install, BUT
There parts department says there (Get This) $151.26 a piece for the yellow fronts and $161.48 for the red rears.........Each
Hello
somthing wrong here!!!!!
The 4 corner lights are bulbs are part # 1194 at $4.50 each come off with a phillips screw-driver, I replaced these yesterday, bought at auto-zone.
Signal stat has new LED lights that look like ours with Different mounts and hookups, there lights are $8.99+ mount $4.00+$1.99 for there wiring assby...Lifetime Warrenty
I may have to redo, the clearnce hummer lights becuase im not into those prices, ill just use clear silacone to seal the lights...........
Rick H2/H3
Old 09-02-2011, 04:31 PM
LIL-TNK's Avatar
2004H2,
If you are going to replace your stock roof markers, then let me know and I will buy them from you.
Well actually I only need one of the "Red rears"
Thanks.
Old 09-03-2011, 04:37 AM
2004H2's Avatar
Default clearnce light bulbs are replaceable......
The clerance lights come to find out are replacable bulbs:
there are clips on the end were there is a notch, you need to run a plastic knife around the rubber on the light, then push at the notch and the clearnce light will come off.
one end of the light has a hook and the other has a spring clip, after removeing light disconnect base from bulb holder and replace the #1194 bulb,
put a small amount of clear silacone on the rubber so you wont have any water leaks and snap it back in place.........
I felt kinda stupid, after they did one for me but, oh well...........
Rick H2/H3
Old 09-03-2011, 01:12 PM
fyr145's Avatar
Tried eBay?
Old 08-06-2015, 07:11 PM
ENIGMA's Avatar
Smile 30 second marker light change
I had a marker light go out on my 03 H2 and found no info on changing them. went to the dealer and they said I had to remove the head liner, they wanted a minimum of 60.00 to change one bulb . Did some more research and found it to be easier than blowing your nose on a windy day. Was going to post a video but couldn't find any way to. Just slide a flat piece of hard plastic under the end of the light housing and you should feel the clip release and just pull up gently. amazing how simple, there is a clip on one end and a hook on the other. If you tilt it up a little you can see which end has the clip on it. Mine were towards the driver side. So this tip should be worth a lot . lol Have a great day.
bobopotato
27
07-30-2011 09:09 AM
jeffwhiteis
02-06-2011 04:20 PM
H3_Hummer
101
01-08-2011 08:18 PM
Fallz
11-27-2006 04:03 AM
CruisinCarAudio
05-25-2006 04:14 AM
Quick Reply: Roof Marker lights
