Removing door panel
Removing door panel
Anyone here ever removed their door panel? My passange mirror has had a pretty bad scrape onit since I bought the truck. Being that it is plastic I don't believe it can be fixed so I am looking to put on a new mirror.
The instructions seem pretty easy, just wondering if anyone has removed theirs before and if there is anything I need to watch out for.
Thanks in advance!!!
door removel
Ijust replaced both my mirrors ,,make sure the glass is up all the way before you start. i used a flat bar to get under the pannel a little more to help pop the clips loose , mine were on really tight , but once the first clip came loose the rest came off ok ,when you pull the pannel off and remove the wiring , you will have to peel back the insulation on the door , i used a puddy knife , and i was able to reuse it , like above , 2 beers ..
if you do a search on mirrors on this board there is a link with pics to help you out .
but it can be done i saved 500.00 over having the dealer do it ....mike
aaronballard0033
07-15-2012 10:51 AM
design8studios
11-19-2011 03:05 AM
mgurgone
11-04-2011 07:35 AM
