rear doesn't open
Old 07-07-2010, 03:35 AM
big toy driver's Avatar
Default rear doesn't open
I can hear the servo working but the handle will not open the rear hatch how do i get the door open so that ican work on this problem. this is an 06 H2.
Old 07-07-2010, 08:00 PM
bosch's Avatar
Default some help
i looked at the service manual and you would have to make sure the lock is trying to work ,, if it does i am ruling out an electrcal problem .
first try unlocking the rear hatch wial pulling and or pushing door in to see if the lock is jamed . if the door still will not open , the only way i saw on the parts brake down was from the inside to remove the inner pannel . if you can get to the bolts .from what i saw , the bottom tie downs at the bottom of the hatch have to be removed it also showed clips or bolts at the top ... good luck ...mike
Old 07-09-2010, 07:15 PM
Thanks for the reply mike it started working again so i'm thinking the seliniod is going bad or isn't working when it get hot here in AZ. i guess i will be down to the dealership for a new one soon.
pauly1052
06-27-2015 04:51 PM
LS12FAST4U
10-06-2014 01:07 PM
johnmully
09-14-2013 11:51 AM
dmurdock
18
02-23-2009 04:06 PM
Dennis
04-03-2007 10:54 AM
Quick Reply: rear doesn't open
