Rear air ride to coil spring ride issue on h2
Old 04-07-2012, 07:47 AM
itsxthexslim's Avatar
Default Rear air ride to coil spring ride issue on h2
Ok so I did my research before I did this conversion. I had bad air springs and did not here compressor coming on anymore so decided to convert to coil springs. I got OE GM coil springsand skyjacker hydro7000 shocks. I drove it for first time after conversion and the back end bounces over the littlest bumps and I here thumping noises from rear over bumps. I rechecked everything to make sure it was tight. The front end makes no noise. All forums I read said truck rides same after conversion. So I'm not sure what I did wrong. Any help would b appreciated.
Old 04-07-2012, 10:54 AM
Indy's Avatar
Maybe snap some pics of the rear setup and we can look if everything has been installed properly. Is the sway bar reconnected?
Old 04-07-2012, 11:03 AM
Yea sway bar is reconnected. Let me get good camera to put pics up
Old 04-07-2012, 11:04 AM
Note I have factory suspension no lift or anything
AndyMac
02-03-2024 10:44 AM
masterpogi
04-13-2014 07:10 PM
XxCC3xX
08-23-2011 02:05 PM
Nxsov180db
05-01-2008 09:38 PM
AZ Hummer
03-22-2008 07:12 PM
Quick Reply: Rear air ride to coil spring ride issue on h2
