Passenger Door Ajar
  #21
Old 11-16-2012, 04:16 AM
Traciemw's Avatar
Default Take it to GM
Good luck Christopher. I suggest taking it to a GM dealer with a Hummer code reader. If they start replacing things and it doesn't fix the problem, it won't cost you if they misdiagnosed. For such a massive vehicle, Hummers are big ole whiney babies!
  #22
Old 11-16-2012, 09:04 AM
I don't deal with dealers. The are over priced *** clowns. I have a local shop that I use that is half the labor rate and half the cost on parts.
On a different note, I will experiment with disconnecting that door from the BCM and see if that provides any results.
One item for note that maybe someone could chime in on. The POWER WINDOW on the same door does not work either.
christianstar
07-31-2019 01:30 PM
kyhummerh2
05-12-2011 08:11 PM
steveng
12-22-2010 09:43 PM
LastLineOfDefense
10-27-2010 01:24 PM
H3gal
07-24-2006 01:26 PM
Quick Reply: Passenger Door Ajar
