Ok the dash noise front left windshield area
#22
I'd think the gears would not be too tough to scan and recreate in a 3D modeling software and then get some place with a small CNC to machine them out of delrin or some sort of UHMW plastic.
That or do what you possibly did and make a mold of an existing and cast your own with some sort of high strength epoxy.
These I made on a Form2 Laser STL 0.0001" resolution from Tough Resin3 (Delrin indeed would be better) and they do work, can't be any worse that they were, i.e. broken to bits!
So the main OD is 25.75mm or 1.0140" for Americans, about the same size as a Quarter which is 0.955" DIA. The inner race has 61 teeth 40thou tall.
As you can tell I've tried really hard to solve this issue and I have a pair that run at full-speed but I've not actually driven a mirror yet.
At the moment I'm working on the motor-casing plastic moulding which also breaks as does the little seesaw arm, I might do another video on this if I can get a working solution.
H3DONIST
05-25-2010 03:15 PM
iowalawhummer
04-03-2008 10:29 AM
parmstrong
01-25-2008 12:33 AM
carissa
04-18-2006 12:48 AM
