Oil Life %
Old 09-23-2010, 10:13 AM
southernH2's Avatar
Default Oil Life %
Can I reset oil life % and change oil message myself without going to dealer? 2003 H2.
Old 09-23-2010, 11:48 AM
chris4851's Avatar
Yes, I believe you hold the check mark on the steering wheel when the oil % is shown then it will reset too 100%. At least on my 2006 it works that way.
Old 09-23-2010, 12:23 PM
DTS62284's Avatar
Turn the key to on(do not start vehicle) depress the gas pedal 5 time with in 3 seconds the oil life will reset.
Old 09-23-2010, 12:49 PM
southernH2's Avatar
I thought you was pulling my leg but the key on pedal depress worked. Thanks for the info!
Old 09-23-2010, 06:37 PM
DTS62284's Avatar
your welcome
Old 10-13-2010, 03:06 PM
coop65sr's Avatar
Not to contradict you DTS62284, but you got it a little backwards--- Manual says depress the gas pedal all the way to the floor 3 times in 5 seconds--- just sayin' to square southernH2 up... it's all good--- I only know this 'cause I was reading my manual yesterday and came across it.... just purchased my '03 this past Saturday and am about to do my first oil change on it this coming Saturday... If anyone can tell me, am I only looking at having to remove the skid plate to be able to get to everything??? Thanks y'all, Chris
Old 10-13-2010, 03:41 PM
TheLimoGuy's Avatar
Yes the pedel depress method will do the trick. A word to the wise though, you may have to try it several times. Sometimes, depending on the vehicle, it just doesn't seem to want to reset on the first couple tries.
Old 10-13-2010, 04:03 PM
olfart's Avatar
skid plate can stay on for just oil and filter. However it's a little difficult to lube all the fittings with the plate inplace
________
OREGON MEDICAL MARIJUANA DISPENSARY
Old 10-14-2010, 01:34 PM
coop65sr's Avatar
Thanks for the info---- Saturday will be my first maintenance on my new beast--looking forward to it though, love to wrench on my own stuff- that way I know it's done right y'all be safe out there
Luigi
04-14-2011 11:28 AM
drtom
01-17-2011 09:23 PM
hummer07
11-18-2008 10:46 AM
Patrick
18
03-10-2008 03:19 PM
HummerGuy
16
09-19-2006 02:35 AM
Quick Reply: Oil Life %
