OEM Luggage rack type Light Bar
I just bought a light bar with no wiring harness and can't seem to figure out why I can't get the lights to power on with a hot and ground? I am trying to test to see if they all work. Anyone know what I'm doing wrong? Thanks
Start with the easy more obvious stuff first....
Check ground wire and hot lead.
if that is ok, then check bulbs in light bar.
Next, go to wiring inside the bar and double check connections.
You can check for continuity in the wire by using a volt meter.
FloridaFeMan
20
02-18-2010 08:19 AM
hummahumma
07-14-2009 09:56 PM
Larain60
02-10-2007 09:19 PM
