noise from interior of car (doors etc)
Hi Guys
now adays i'm hearing lot of noise from doors and at the back side.
inside the car where there is plastic there is noise...
even at the back, we cannot open mirror, still there is noise of the plastic which is under those mirrors.
any advice??
fed up of this noise :-(
any advice??
i have the same problem,
i am going to take the doors apart and see what i can add, it seems the door panels rub against the actual door so i will try to add some double sided 3m tape in spots to act and insulation, will let you know how it works
thanx buddy
i remember wen i bought this car, there was some voice from the doors, wen we sit we put our hand on the door, at that place it was loose from inside so i fixed it with nail and it gone away.
but now the voice is alot ...
if possible for u, please take the snapshot for wat u do to your doors...as than it will be easy for me to fix the same way.
Thanks alot
Thanks alot
one more thing..wat about interior at the end where we fix spare tyre.
will u fix that also?can we move that plastic and put the tape on it??
please let me know..it is also making lot of noise..
@sohaib_fouzi
I felt worse cause I hear the Voice in my head , I even went to the mechanic but he sent me to the doctor ... Voice/Noise
AHHH just kidding ... I did ask the same a few post ago and yes unfortunately everyone prior 08 have the same issue .
If 3M tape works , please let me know
felt tape is what we use here. its a dealer secrete lol. remove the panel and try to find the area that makes contact and attach the tape there and replace any old door panel pins as needed. it works for the dash as well and will work for years to come. it holds it tighter and the panel will rub against the felt instead of the metal door.....
@h2 miami
still i didn't do anything with my doors..
waiting for reply of HUMMER_DUDE....he said he will fix it and then will tell us...
until than feel free to listen to that DOOR BASED MUSIC...
@theboss
glue will not be better solution for this noise...but 3m tape will be....
i'm thnking to do it this weekend...hope i'll get time.
@coachwesh2
dear, did u put 3m tape in ur dash to remove the noise?
because i hear a little noise from my dashboard also...but now for me, noise from doors is real headache...
@theboss
@coachwesh2
