Nitto Terra Grapplers - 325 60 20
Old 03-27-2014, 06:35 AM
Rags747's Avatar
Default Nitto Terra Grapplers - 325 60 20
What air pressure are these normally run at on the road? These are on an H2
Old 03-27-2014, 04:28 PM
H2CANEPADESIGN's Avatar
Well max air on that particular tire should be about 50 psi.
so you can run anything between 35 -50 psi. I usually run about 50 when I'm towing and less when I'm not so that is doesn't drive like a brick.
Old 03-27-2014, 09:01 PM
HUMVEH2's Avatar
I'm at 45 psi
Old 03-28-2014, 06:10 AM
Rags747's Avatar
Thx guys...exactly what I was looking for
Old 03-30-2014, 05:16 PM
I keep them at 40psi.
Old 04-03-2014, 05:50 PM
Nate2106's Avatar
How tall are those tires... in inches? And how wide of a rim do you need to fit them? Thanks guys
Old 04-03-2014, 08:31 PM
ukdave's Avatar
same size as mine i run 40psi
Old 04-04-2014, 11:38 AM
I believe they are 35" and my rims are 10" wide.
Old 04-10-2014, 11:31 PM
Da Brick's Avatar
how much do those suckers weigh?
Old 04-11-2014, 06:21 AM
strippersteel's Avatar
I keep mine at 45psi
Quick Reply: Nitto Terra Grapplers - 325 60 20
