New Gauge Face For my H2
I just changed my 07 - H2 Gauge face with the escalade style from usspeedo - I really like it
I always thought the illumination was white (kinda warm white) and a little dull looking, however I thought the font style was OK - I thought a more aggressive font type would always look better. So after looking around I bought the face plate replacement and I am very very happy.
I also found out the interior lighting is really a very light blue, not white - the back of the stock gauge plate had a light blue filter, however when illuminated - looks dull white
The new gauge face has a deeper blue color to it - (pic attached) - I also changed the gauge needles to red for a better contrast - the new color looks awesome and is more soothing to the eyes and brings out the blue in the rest of the interior lighting - what a difference
The font type looks more sophisticated and cleaner looking and fits the H2 look better IMO
It was pretty easy to install, however it took me a long time to put the needles back on correctly - I had to keep taking them off and adjusting them until I got them correct
The set up cost me about 170.00 for the gauge face and needles
Believe it or not it was pretty easy - it took about 30 min. And was pretty straight forward - it just took a few times to get the needles on correctly so they would be accurate - I am not a great mechanic either, however I did do this pretty easy - I looked up a few YouTube vids to see how to do it
I think I got lucky having a 2003.... it came stock with white face... and that's what I've put in everything I have owned...
my 2007... not a fan of the faces... but my wife drives it... so it's not my issue....
This is a easy mod - you take off the 6 hex head bolts that hold the left & center air vents and then the leftvair vent assembly pops out (held on ehth clips) pull the center air vent back (held on with clips) however you don't need the take the center air vent out, it just pops forward enough so you can get to the gauges.
There are 2 more hex yeas screws on the left and right of the steering wheel, and once those are out the gauge cover pops off.
The last thing is there are 4 more small bolts the hold the cluster in place - once those are out -un plig the cluster and you can work on it
I used latex gloves (washed the powder off of them) and using a small flat head screw driver - poped off the plastic gauge cover, and then you can work on it - the gauge face plate just comes off after you take the needles off (instructions are included as well as a piece of paper with the copy of the gauge face so you can mark the position of the gauge needles)
I did make a mistake with the needles a few times and had to take them off and put them on again - was not hard
If you YouTube usspeedo gauge replacement or change - there are a bunch of vids showing how to do it - it took me about 30 mins and is pretty easy - the pieces come off in a way you won't scratch anything
swr930porsche
09-11-2020 09:25 PM
H3Alpha21
02-19-2012 09:48 AM
Doc Olds
10-08-2008 10:57 AM
