Need opinions..........
I can not release the Extended Ride Height for my 2008 Hummer H2.
I tried million times to deactivate by the switch on the instrument panel. I hear the compressor is working but remaining at the same height.
By the owner manual if the vehicle is at Extended Ride Height and the speed exceeds 40mph(64km/h) the system will automatically return the vehicle to Normal Ride Height – I tried this, too- I went with 100 km/h and is still at Extended Ride Height.
Has anybody an idea what should I do?
When you start the vehicle, does the ride height light come on by itself? Maybe there is something wrong within the switch, causing it to be depressed all the time. Also, is the Air Compressor working all the time? Even with the raised height, the Compressor should shut off once the 2" extra have been reached. No need for it to pump air into the bags unless there is a leak. Good luck, Indy.
solarflare
26
06-03-2008 07:36 PM
importkiller
20
03-17-2008 10:48 AM
generh2
01-21-2008 07:29 AM
mfish
16
07-15-2007 02:45 PM
