need lamp socket for rear bumper
Realized that was the reason my light wasn't working. Pins were corroded and snapped off. Been to the dealer and I have to buy the whole light assembly. So, like i say, has anyone got a lamp socket for rear bumper light ?
Thanks, Paul
Thanks, Paul
I'm almost wondering if its integrated into the entire harness/trailer hookups for those bumper lights. If so your best bet would be to just splice in a new socket which would be insanely cheaper than a new harness.
I had the same problem on my first Hummer. Mine melted. I checked everywhere. I could only buy the entire assembly. I ended up pulling the bulb out of the good one and just blacking out the lenses. You could easily get one out of a scrap yard. I was just too lazy!
Hi did you ever solve this?
I have the same problem and I'm finding AC Delco sockets but not sure which one is the correct one.
Autopartswarehouse lists the following with pictures
LS176 (what I think it is)
LS44
LS117
LS59
Like you I don't want to spend $300 for the whole damn light housing to get a $40 light socket.
LS44
LS117
LS59
Well after searching all damn day and having to use Google image search to match up one that looks like the one from the lower bumper I finally found it!
No more spending $300 with GM for the whole freaking light assembly. Here's the info for anyone searching for this in the future
Hummer H2 SUV 2003-2009 Rear lower bumper turn signal / marker light left or right side light bulb socket housing GM part # 12335899. It will say its for the front grill turn signal but I confirmed that it is the same part via the manufacturer part number (ending in A22) on the actual socket housing.
So there ya go fix it the right way for $4 on Amazon vs. $300 at the dealer.
UPDATE: I made a Youtube video to SHOW YOU they are the same. Check this out
SShockwave
01-08-2012 01:57 PM
