Need help.....
Old 04-24-2011, 12:46 PM
Harry007's Avatar
Default Need help.....
I've just purchase a used h2 hummer, im from the UK.
Basically. It recently had a loose positive terminal on the batter. So every other odd journey i used to do, when i went to start it, it wouldnt, a quick wiggle with the terminal the car would start. So great.
Came home as usual the other night. Parked up etc. Next morning I tried to switch it one and nothing!? Its like the key gets stuck in position 3 and will not allow to crank?
Battery is fine.
There is light on the dash like, a lock etc in amber on.
When I try to start it, i can hear everything react, i.e pump etc. But thats it.
All fuses are fine.
Gearbox is fine and selects gears fine.
Since then I have tightened the battery terminal.
The ignition gets stuck as if i have it in a steering lock or something.
I'm dead confused??!?!?
Old 04-24-2011, 07:16 PM
odonnks's Avatar
Sounds like you've somehow enabled the 'Passlock' system.
Its a anti theft system that disables starting of the engine.
Not sure how to disable it. Per the manual of my 03 H2 it says that if it won't start after 3 tries service is required.
Someone else here may have a tip on what to do. Also try searching 'Passlock'
Form another thread here from someone reporting the same issue...
"In case this happens to somebody else, I just went to the 2, opened the door with the key, turned the ignition key and the Hummer started right-up. Must be some type of theft prevention sequence that gets out of synch..."
Old 04-24-2011, 07:19 PM
Indy's Avatar
I can't help you with your problem, but I must compliment you on buying a H2 in the UK with the high gas prices there It must be quite a site on British roads....and I'm sure you're every gas stations favorite customer Hope you find the problem with your Hummer...maybe a fuse...did you try cleaning the terminals on the battery....I don't think the H2 came with a steering lock, but I might be mistaken. Cheers....
Old 04-24-2011, 11:36 PM
JDTDBD's Avatar
****, I just paid $127 for a full tank at $3.78 a gallon in the U.S., they love me in Missouri and I am about to move to New Jersey where it is even more per gallon lol.
But back to the thread, I had the same problem with my wifes H3. She locked the truck with her key fob and I used the spare key to unlock the door. I opened the door and the truck starts to beep (the alarm system triggered) and then I start the truck and it goes off and everything is normal. One day I did this and the same thing that happened to you happened to me. It ended up being the battery. i brought it to Autozone cause they will check and charge for free, They checked it and said it was still good, so they kept the battery and charged it. i reinstalled it and it worked for a day. next day same thing. Replaced the battery and no issues since. Just my 2 cents. Hope you figure it out.
Old 04-25-2011, 04:56 AM
odonnks's Avatar
Also try unlocking the drivers door with the original key. Not the key fob. I've seen something about waiting 10 min also.
importkiller
29
01-15-2008 02:51 AM
WOLFGANGSTA
02-11-2007 03:55 PM
crc2k
09-01-2006 04:03 PM
skeeet
03-16-2006 05:21 AM
efrainl956
05-16-2005 10:46 PM
Quick Reply: Need help.....
