need fast help, my diagnostic port wont work
Old 01-18-2011, 05:48 PM
crazygn's Avatar
Default need fast help, my diagnostic port wont work
i have my buddys scan tool tonight but it wont power up , i checked both pcm fuse under the hood and both are fine.
any clue guys
Old 01-18-2011, 08:10 PM
calif phil's Avatar
Is the Check Engine Light working when you turn the key on? If so I would try another scanner. If the Scanner is OK it would about have to be a wiring problem at the ALDL connector.
Old 01-23-2011, 10:35 AM
DB5's Avatar
DB5
DB5 is offline
check the cig lighter fuse, its the power source at the dlc for the scan tool. the fuse is in the under hood fuse block.
simota1
11-24-2021 12:45 PM
jmH3
08-21-2017 09:17 AM
windycitykid
06-25-2014 11:02 AM
greg260
08-21-2013 09:07 AM
suey 1958
02-24-2011 11:42 AM
Quick Reply: need fast help, my diagnostic port wont work
