Need Advice......
Need Advice......
Hi All, I have a "03 H-2 with 118,000 miles. I know I have an issue with the air suspension. It's been acting up for about a month. Today while about 60 miles from home I experienced the following.....My "other half" went to lock the doors from the passenger side. All of a sudden the electronics went crazy. All the gauges EXCEPT the speedo and tach stopped working, the t/c light came on, radio stopped working, DIC displayed "unknown driver" and then "driver 1". It would also change from "service air suspension" to "service 4wd". The windows stopped working and the dashboard illumination would blink on and off and at different brightness. At one point I stopped for dinner and disconnected the battery for about 1 hour. When I reconnected it everything was fine for about 30 miles and then it started all over again........Does anyone have any ideas ??? I'm going to try to get it to the dealer tomorrow.....
Thanks in advance.....Larry in So.Fla.
UUUHHHMMMM......... WOW!!!!! NEVER heard of anything REMOTELY close... Do you have a contact person or dealership locally. If not, I can hook you and Steve @ Classic Hummer/Chevy up. The service dept is still open & I have nothing but good things to say bout the whole group!
Wish ya the best of luck though!
I just wonder if the pass side door lock switch is shorting out ,if it was running fine before and that is what she did i would try disconnecting the door wiring connections on that side and unhook the battery again and see what happens , you might have at the same time shorted the bcm like the above poster said ...mike
When all was said and done...........replaced both air bags AND the compressor. Dealer said the constant running damaged control module AND the comp. Also said the "computer malfunction" was most likely caused by the overload of codes from the suspension system.....They could not duplicate the computer problem.
BOTTOM LINE..........a week at the dealer and $3700. Had it back for a week now and "All is good"..
tlzkaasen
11-18-2010 04:24 AM
Sabrinat1
12-05-2006 09:24 AM
AbadR1
10-26-2006 05:24 PM
