Marker light question
Old 03-05-2011, 09:04 PM
h2_32137's Avatar
Default Marker light question
My driver side rear red marker light is out. The "running light" on my left back is out as well. The bulb in the back functions when I press the brakes but does not stay on otherwise. Is this a result of the marker light being out? Does anyone know how to fix this? Replacing the bulb did not get it corrected. Also, does anyone know where I can buy these marker lights? In person or online is fine. I look forward to your responses.
Charles
Old 03-07-2011, 03:25 PM
luda81's Avatar
Charles
Well it seems like they are wired together. Did you check the fuses?
Old 03-08-2011, 11:04 AM
h2_32137's Avatar
Default marker light
I did check the fuses up front. They are all good to go. Guess i will replace the market light and see if that resolves the issue. Any other ideas?
Charles
flrtrader
11-29-2017 01:19 PM
alexismya
12-24-2011 07:35 PM
Hummer2006h3
03-03-2011 07:36 AM
Cruizer
05-02-2007 08:05 PM
Quick Reply: Marker light question
