Low Oil Pressure H2 2008
Old 05-14-2015, 06:35 AM
ryaleon's Avatar
Thank you for the info and video. I swapped out my sensor yesterday and unfortunately for me it wasn't the culprit for me.
  #22
Old 05-19-2015, 08:06 PM
ryaleon's Avatar
Seems like the filter was the culprit in my case
  #23
Old 05-20-2015, 07:00 AM
man-of-war's Avatar
Let me know which brand oil filter was defective.
I used Mobil 1 oil filter this spring. The temporature diped to 0 last night here in Totonto Canada and the old valve ticking is back
Im wondering if this engine has adjustable rockers.
  #24
Old 05-20-2015, 07:22 AM
ryaleon's Avatar
It was a Bosh filter. I am now using Mobile 1
  #25
Old 08-19-2015, 05:43 AM
S Reynold Gudam's Avatar
Hello. Suddenly I lost my engine oil pressure. Changed the sending unit,but still same. Manually check using external pressure gauge it show normal reading +-40si idle. What could be problem here? my engine check doent lit.
  #26
Old 08-23-2015, 04:50 AM
Anybody? Could it be fuse or something else? It went up to +-5psi before I crank n back to zero after idle.
  #27
Old 08-23-2015, 09:23 AM
H2Miami's Avatar
Off topic ... You guys are making me jealous with those 2008 dash pics .. Wish I could keep my 2006 with some 2008 interior
BTW mine att idle is always a little under the 12 mark then after passing the 1000 RPM Oil pressure increase . I guess this is normal
Here it is a pic of mine
Cond :
Outside Temp 80
Engine temp 205
transm temp 140
RPM 1500
Speed 35 mph
PlainoH2
08-29-2021 08:40 PM
madmayo
21
11-18-2014 04:16 PM
Kinder82
04-04-2013 08:30 PM
PlainoH2
11-18-2010 06:19 AM
sakodik
12-02-2008 09:18 PM
Quick Reply: Low Oil Pressure H2 2008
