Low Oil Pressure H2 2008
Old 04-01-2015, 08:13 PM
woodwardsh3's Avatar
No but you have to remove the intake to get to them. Why do you think you need new lifters.
Old 04-01-2015, 08:17 PM
Have you contacted GM service and asked what is normal oil pre. for the 6.2
thats where I would start.
Old 04-02-2015, 12:04 AM
Synthetickiller's Avatar
If I get a chance to drive my H2, I'll see what it's shows tomorrow.
I've noticed it seems low (below the half way mark).
I just changed my oil 200 miles ago & I check it today. Still full.
Old 04-02-2015, 10:50 AM
madmayo's Avatar
Just wondering if used the Lucas oil additive with the most recent oil change. You stated in the previous oil change you used Lucas. If you didn't use it with the RP change I bet this is where you have lost a little oil pressure. As you know the stuff is like molasses and could bump up your oil pressure slightly. Especially from a cold start up. I use Lucas as well but only during summer months.
Old 04-02-2015, 06:52 PM
We don't you Pascals in the US (and we really should!). 1 PSI = 6894.76 (let's just say 6895 for simplicity's sake).
Here is the oil pressure while driving at least 45+ miles (about 72+ km) 80F (26.7C). I had a cool down period of 45 minutes after 30 miles of driving.
Here's the oil pressure at idle in the driveway after the entire trip:
I'm using full synthetic oil. The H2 has over 108k miles (173k km).
Attached Thumbnails Low Oil Pressure H2 2008-psi-driving.jpg   Low Oil Pressure H2 2008-psi-idle.jpg
Old 04-02-2015, 07:02 PM
looks good to me.
Old 04-02-2015, 07:37 PM
citiboy's Avatar
That's exactly like mine.
Old 04-26-2015, 05:09 PM
man-of-war's Avatar
This oil pressure sensor was the culprit for my low oil pressure. The ticking noise in the engine still persist.
I'll post some picturs of where the oil pressure needle is now
Attached Thumbnails Low Oil Pressure H2 2008-img_20150426_095819373.jpg   Low Oil Pressure H2 2008-img_20150426_095829584.jpg
Old 05-12-2015, 11:32 AM
ryaleon's Avatar
My 08's seems a little lower than usual although I can't remember for sure. I work overseas so am gone a good amount of time.
Mine looks to be a little lower than Synthetickiller's in the pics he showed. I'm basically sitting at the 20 psi mark at idle. I have never seen a low oil light show up I'm just a bit concerned.
How much was the oil pressure sensor and where is it located?
Old 05-12-2015, 08:08 PM
man-of-war's Avatar
Quick Reply: Low Oil Pressure H2 2008
