LED side marker lights
Anyone have to replace their LED side marker lights yet? My rear passenger side one stopped working. I see that it is LED, which stinks that it went out after 4 years. But after unscrewing it, it seems that they are hard wired in, or atleast I cannot see how to unattach it. The GM Dealer quoted me around $90just for the unit, but I have no clue how to replace it other than splicing it in, and there is no way I'm paying them to install. I haven't purchased anything yet, maybe someone can lead me elsewhere.
RE: LED side marker lights
you have to take off the interior plastic molding under the windows, that's where the connector is- and to do that you have to remove all the molding around it. pain in the ***, but that's where the connector is. that's why it costs an hour of labor to replace it.
Removing interior trim panel in cargo area
Mine just went out as well. Does anyone have the following document "Door Sill Plate Replacement - Rear" for properly removing the cargo trim panel in order to replace the market light?
Interior plastic molding.
Do you know where I can get a diagram for the interior molding? Or can you tell me what panels need to be removed? Sorry this very simple project is kicking my A$@.
Passenger seems a lot easier than the Driver side!
Is there any hope, or should I just remove all the plastic? Thanks!
Remove the interior panel. The pockets can be removed but they are nearly impossible to snap back in. The interior panel is not that difficult to remove and replace. Go slow so you don't break plastic.
